I am trying to suppress the detail line on my report but nothing I have tried has worked.
There is a field on my report called @Results 2 which looks like this:
If {Observe.Obs_Float} <> 0 Then
CStr ({Observe.Obs_Float})
Else
If {Observe.Obs_Choice} <> 0 Then
CStr ({Observe.Obs_Choice})
Else
If {Observe.Obs_String} <> ' ' Then
{Observe.Obs_String};
I want to suppress lines that have a space in the @Results 2 field. I have tried putting this in the conditional suppress:
{%Results 2} = ' ';
That didnt work.
So I created another field called @SetUpDSuppress to do this:
NumberVar ShowDetails;
EvaluateAfter ({@results 2});
If {@results 2} = ' ' Then
ShowDetails := 0
Else
ShowDetails := 1;
I put it on the Detail line (and it works). In the conditional suppress on the detail line:
ShowDetails := 0
That didnt work either.
I am guessing it has to do with when things are being evaluated but not sure how to control it. Any suggestions?
RenaG (BOB member since 2011-04-11)
