Summary vs Detail when exporting to Excel
We have a summary report (ie no details just the groups and totals for each group). The report appears fine, but when we export the data to Excel, we get the detail rather than the summary. What’s up with that?
TIA
D
hueymoo (BOB member since 2005-02-25)
you are probably exporting data from the data manager window - this way you export the data of dataprovider(s), it means the most detailed data as you get it from database.
If you use BO 6.x then get your grouped data (data in the tables) into Excel via File → Save As → XLS format.
Have a look also in BOB Reporter’s FAQ:
Marek
Saving the report directly in excel format is available in BO from version 6.0 or higher.
If you have more than 1 tab. You have to use ‘Save As’ option individually for each tab.
