Sum of Values between Dates
Hi Members,
I need your help on below issue.
I have a report, returning the Billing Date and the quantity and I created my own variable KE Wk Range; basically adding 7 days to the billing date.
Now I want to see the total quantity between these days.
My report is showing the billing dates, the KE Wk Range as dates.
I am adding below, however I am getting the total qty and not only the quantity for the next 7 days for each billing date record.
=Sum([NR Tot Qty]) Where ([Billing Date] Between ([Billing Date]; [KE Wk Range]))
Could you please advise here?
Flooo
Flooo (BOB member since 2013-01-23)
make sure that all date-fields are formatted correctly as date.
test every single comparing-step with a simplified formula
and try using <= and >= instead of “between”
n8aktiv :de: (BOB member since 2018-12-29)
I was poking around with that earlier and its not working.
its still returning the total of table.
I also added foreach at the end.
=Sum([NR Tot Qty]) Where ([Billing Date] >= [Billing Date] And [Billing Date] <= [KE Wk Range])
=Sum([NR Tot Qty]) Where ([Billing Date] >= [Billing Date] And [Billing Date] <= [KE Wk Range]) ForEach ([Billing Date])
I also added a screenshot of my report.
Any further ideas?
Thanks in advance
Floo
every row in your example is matching the conditions so total is correctly summed up !
[Billing Date] = [Billing Date] (whatever that is supposed to do ?!)
and
[Billing Date] < [KE Wk Range]
you have to rethink your logic !
In the end I would like to get the running sum value up to the date of the KE we range for each billing date.
Is this possible?
Flooo
if you want a running sum, then you have to use RunningSum() :wink:
with this syntax:
RunningSum([measure];[Row|Col];[(reset_dimensions)])
Unfortunately it’s not working how I am using it.
For the billing date 12/1 I want to get sum of all values from 12/1 until 12/8 returned in the same line, 139.2 Mu.
For 12/2, the total from 12/2 until 12/9, 146.5 Mu
Flooo
if there is always the same 7days-distance you can try this:
=RelativeValue([NR Tot Qty];([Billing Date]);1)+
RelativeValue([NR Tot Qty];([Billing Date]);2)+
RelativeValue([NR Tot Qty];([Billing Date]);3)+
RelativeValue([NR Tot Qty];([Billing Date]);4)+
RelativeValue([NR Tot Qty];([Billing Date]);5)+
RelativeValue([NR Tot Qty];([Billing Date]);6)+
RelativeValue([NR Tot Qty];([Billing Date]);7)
Thanks a lot! This solved my problem and is returning the data I was looking for :slight_smile:
Thank you!
