Sum of first two blocks of a break implemented report
I have a requirement for calculating the Sum of first two blocks of a break implemented report.
For Example, Report has 5 years of data. 2005-2009. Breaks have been implemented on year.
Now i need sum of data of 2005 and 2006 only.
avbaby :india: (BOB member since 2009-05-09)
The formula should be:
=Sum([measure data]) Where ([Year] InList(2005;2006))
JohnCW :us: (BOB member since 2004-08-05)
That was only the example… Years are not static. They are dynamic. Not necessarily 2005 and 2006
Are the requirements for the first two blocks static? For example, is it always “current year minus 4 years” or something like that? I would create some type of variable based on that to represent those first two blocks, and then use the example I provided.
You can say its the sum of MIN of YEAR and (MIN OF YEAR)+1
