SuccessFactors OData Connection
All,
Has anyone connected to SuccessFactors Employee Central or any other modules using the OData API.
I have been trying to use that and so far it allows me to use the OData object as a Source in the DataFlow but it gives no option to use it as a Target.
I have been scouring the documentations for a while but with no luck.
I am pretty sure it is some access issue at the SF side, but does anyone has any experience on this???
