I created a sub report that returns Top 20 values. When I total it it gives me the overall total, not the total of the top 20. Is there a way to accomplish this?
It seems so easy but I’m stuck.
tcoyer (BOB member since 2009-08-31)
You can create formulas to get the total of top 20 values.
Cheers!!!
Manish
cr_manish (BOB member since 2009-07-30)
can you point me in the right direction?
I’m finding formulas for Nth largest, but not a top N formula.
nm I eventually got it.
thanks.
have you manage to find a way to have the subtotal?
i try a loop zwith the nthlargest function but the function does not accept a variable…
g_nat (BOB member since 2009-09-08)
