Where does the repository get its substitution parameters from? Today we had them messed up and were unable to correct them up till now.
After accidentally importing an ATL that contained a complete repository instead of just a project, we got an error with the Address Cleanse, stating that it could not locate the address dictionaries. Since we run the job server on a Linux system, we were surprised to read a windows file path in the error. The location is defined by a the substitution parameter $$RefFilesAddressCleanse, which can be viewed/changed in the Designer via Tools --> Substitution Parameter Configurations.
The only thing I could think of, was to export our projects, jobs, etc, and recreate the repository (we actually deleted the tables from Oracle). But still the substitution parameter $$RefFilesAddressCleanse pointed to a directory on the Windows client machine (the one the repo was created from). I would expect to see a Linux path there.
My questions:
[list]Where does the repo get these values from, as during its creation, it has no knowledge of what Job Server is going to be used? I thought it might have something to do with (re) synchronizing the repo with a Job Server from the Server Manager, but that did not have any effect.
[/list][list]What should be in these variables:
That’s truly an old post, but unfortunately it has never been answered. As far as I can recall we have created a new repository to set things straight again.
Right-Click on the Local Object Library --> Repository --> Export Substitution Parameter Configuration and export it. You are done and ready for import into another repo!!!
if you are on DS version earlier than 14.0 (DS 4.0) then I think you can get the ATL of the older version of sbvar_store object from AL_LANG and AL_LANGTEXT
SELECT * FROM AL_LANG WHERE NAME = ‘subvar_store’ will give you the object_id of the all the version of the substitution parameters
SELECT TEXT_VALUE from AL_LANGTEXT WHERE PARENT_OBJID = ORDER BY SEQNUM;
append all the rows from the output, this will give you the ATL of the substitution parameters for that version of the object, you could try importing this ATL
you can first try this on a clean repo for testing purpost before actually trying it out on actual repo
from DS 4.0, only the latest version is maintained in the local repo
