Sub Report Issue
We have a report when we run it directly in Infoview, it runs fine but we i am using this report as subreport in another report (The logos and objects present in Page Header are kicked into Report Header) we are facing issue of duplicacy of page. i.e same values including detail section are repeating in two pages. Basically when we were running the report as one stend alone report we were getting only one page but when we are running the report after using this report as sub report, we are getting two pages of data where second page is having the same data which was there on first page.
I am new to Crystal Reports, please help me out.
Pathak
pathak (BOB member since 2009-02-19)
Hi Pathak,
What section of the main report have you placed the subreport in?
Andy.
andyherm :uk: (BOB member since 2008-09-26)
Kindly check the connection links of the two reports and also the formatting of the sub report. You may supress the header and other information you dont need in sub report. In this way it will compress automatically to the detail you want to view. Check also the section of the main report you placed the sub report ( stated by andyherm)
nahtanoj :philippines: (BOB member since 2009-07-08)
