Hi I am working with multiple databases. One universe is created from the tables of one database and the other one is using store procedure from the other database. I have created the universe from the tables but the universe from store procedure is giving some problems. After establishing the connection When i bring the store procedure in the universe it ask me to input some value and edit the prompt label. which i dont quite uget how to input. I analyze the store procedure and try to input the value that i see in the store procedure but still doesn’t work. can anyone what can be done.
thx
[/code]
Ahm318 (BOB member since 2012-08-31)
