Start BO automatically
Hi all,
I am a new user with BO and I would like to know how configure BO to start automatically as a service. What can I do?
Sandro
sbrandao (BOB member since 2005-09-22)
You have to shutdown webi then use the config tool under Program Files / BusinessObjects on the server (Windows?).
Select to Modify the Cluster and locate the Service parameters.
Select to auto start and run as a service.
Close and reboot the server.
WEBi should start up.
Thanks Mike. The changes worked very well.
