I have a dataflow with a query transform which does a join of 3 tables and has an orderby clause on the result.
This transform would be giving output (to flat file)of nearly 15,000 rows .
I have 3 such dataflows which run in parallel since the source tables are differenct for each dataflow.
Please advice if it would be better to use a SQL transform to perform this operation instead of query transform.
Since I have a doubt that using query transform causes BODS memory to peak for a few seconds.
SuCheri (BOB member since 2011-11-18)
If it is a cross join then you may end up having BODS consuming lot of memory and eventually log becoming full. Else query transform should work well.
Arun
Arun.K
(BOB member since 2011-10-18)
well …it is a cross join.
Cross join is a tricky situation which might create issues in BODS as well as the database. You may have to create a relation ship between the tables to work.
Arun
Arun.K
I don’t think the memory shoot is because of the join really (may be
But how come cross join on for all? Are you sure on that?
How many Optimized SQL’s generated on your dataflow? 1 or 3?
ganeshxp
(BOB member since 2008-07-17)
