SQL Scripting Error in Rule Definition
I am attempting to write a rule that checks a date, stored as a epoch unix timestamp integer, and have it fail the rule if that date is greater than current date. the code is as followed:
DECLARE
$EST_DATE datetime;
BEGIN
$EST_DATE = SQL(‘dataconnection’, 'SELECT DATEADD(s,epcoch_date_field, ‘1970-01-01 00:00:00’) From table) ;
If ($EST_DATE < sysdate())
RETURN TRUE;
ELSE
RETURN FALSE;
END
I get the error for the SQL script line of
Syntax Error at . (COR 10611)
Any ideas on how to accoplish this or resolve error?
daguas (BOB member since 2011-06-29)
Update on Issue: I have corrected the original sytax error: I neglected to preceed the embedded qoutes with the , I have done that now I get a new error that currently does not make sense to me.
I now get the error on the SQL line 4: Datatype incompatibilty: found type But expecting . (COR-10600)
The DATEADD SQL Function returns a datetime, not a varchar, so I am unclear as to why I would get this error.
Any thoughts, insights or assistance would be greatly appreciated!
What does happen when you execute the code in the SQL Server Management Console? Does it work then and what is the SQL text then exactly?
what version of IS is this IS 4.1 SP1 ?
