SQL Override-Oracle Hints
I’m using V5.1. I want to override an existing data provider query with a query with oracle hints.
When I try to do this, error ORA-00911: invalid character appears
Would like to know if hints are allowed. If yes and any leads on solving the error
Meena
meenaj (BOB member since 2005-01-12)
A search would have led you to lots of threads about hints… Try https://bobj-board.org/t/15442
jobjoris :netherlands: (BOB member since 2004-06-30)
You should be careful while overriding the SQL, perticularly on syntax of SQL. It will be helpful to provide the suggessions If you could provide the SQL.
bvrswamy :india: (BOB member since 2006-06-18)
