SQL Case statement ranges and literals
SQL for universe object has a case statement to create range literals(data in quotes below) on a report using the between keyword. When no data is found for the between clause the range is not printed on the report. How can I force the range literal to print when data for a range does not exist ?
SQL :
(CASE WHEN  @Select(PSCF\principal balance)  between      0.01   and      999.99   THEN         '0.01    to      999.99'
           WHEN  @Select(PSCF\principal balance)  between   1000.00   and    9999.99   THEN   '1,000.00   to   9,999.99'
           WHEN  @Select(PSCF\principal balance)  between 10000.00   and  19999.99   THEN  '10,000.00  to 19,999.99'
           WHEN  @Select(PSCF\principal balance)  between 20000.00   and  29999.99   THEN  '20,000.00  to 29,999.99'
           WHEN  @Select(PSCF\principal balance)  between 30000.00   and  39999.99   THEN  '30,000.00  to 39,999.99'
           WHEN  @Select(PSCF\principal balance)  between 40000.00   and  49999.99   THEN  '40,000.00  to 49,999.99'
           WHEN  @Select(PSCF\principal balance)  between 50000.00   and  59999.99   THEN  '50,000.00  to 59,999.99'
           WHEN  @Select(PSCF\principal balance)  between 60000.00   and  69999.99   THEN  '60,000.00  to 69,999.99'
           WHEN  @Select(PSCF\principal balance)  between 70000.00   and  79999.99   THEN  '70,000.00  to 79,999.99'
           WHEN  @Select(PSCF\principal balance)  between 80000.00   and  89999.99   THEN  '80,000.00  to 89,999.99'
END)
gtherrie (BOB member since 2008-02-29)
Welcome to B:bob:B!
This Reporter’s FAQ should give you a clue how the BO report should be built so also missing ranges are displayed:
A second data provider will not work as the ranges can not be stored anywhere. I believe the best bet is to modify the universe object to enable printing the ranges when there is no data found for a particular range.
Any ideas how to make the case else statements will function as below (this is the plan but this doesn’t parse):
              ELSE '0.01    to      999.99'
              ELSE  '1,000.00   to   9,999.99' END
              ELSE '10,000.00  to 19,999.99'
              ELSE '20,000.00  to 29,999.99'
             ELSE '30,000.00  to 39,999.99'
             ELSE  '40,000.00  to 49,999.99'
             ELSE '50,000.00  to 59,999.99'
             ELSE '60,000.00  to 69,999.99'
             ELSE '70,000.00  to 79,999.99'
             ELSE   '80,000.00  to 89,999.99'
Unfortunately CASE WHEN statement does not work this way :nonod:
I think that the only solution is to use the 2nd dataprovider. If it is not an option for you for any reason then I am sorry but I can help here :nonod:
thanks for your help, I am new at this and need more detail to understand your proposed solution. The example you had forwarded shows a solution in which missing months can be determined by using a second data provider that contains all the months, correct ?. I understand that a calendar object could compile a list of the months and be used by the first data provider. In my case, are you suggesting that I create an object that has all the ranges needed and tie that to the first data provider that aggregates all the data by ranges (between) ? If so, I am not sure what form that would take. How would I have the second provider (range literal) match the range (between SQL) in the first provider and aggregate two other measures for all the ranges ?
How about using a DB function to generate a band name for any given input value. Below is an Oracle function - its fairly generic so could be adapted to other DB syntax. It takes 4 numeric values : input, band width, min value, max value.
 create or replace function get_band (
       vInp  in Number,
       vBandW in Number default 100,
       vMin  in Number default 1,
       vMax  in Number default 1000)
RETURN varchar2 IS
vLower NUMBER  ;
vUpper NUMBER  ;
BEGIN
IF vInp < vMin    THEN RETURN '<' || to_char(vMin);
ELSIF vInp > vMax THEN RETURN '>' || to_char(vMax);
ELSE
    vLower := vMin + TRUNC((vInp-vMin)/vBandW)*vBandW ;
    vUpper := LEAST(vLower + vBandW -1, vMax);
END IF;
RETURN to_char(vLower) || ' - ' || to_char(vUpper);
END;
For example, if you require intervals of 1,000 for all values between an anticipated min & max range of 1 and 100,000, you could use the above function as a dimension object in your universe : get_band(, 1000, 1, 10000). This will generate bands automatically & give bands of < 1 or > 100,000 when values lie outside the min max range prescribed. It will be lot neater then multiple CASE WHEN statements.
Neil
amiboberd (BOB member since 2007-05-02)
Sorry, example should be
get_band(, 1000, 1, 100000)
Just researching this topic myself.
Looking at DR’s solution. It seems to be dependent on having a column that you are banding your results on (i.e. Month Name). Gtherrie’s issue is that there is no column to use in the second data provider.
I am looking at a similar issue where a measure of minutes between processes need to be banded into performance bands (<5mins, 5-10mins…)
I was thinking that worst comes to worst I can create a derived table in the universe that has a row per required band (using unions (I know, I know)).
Thoughts?
dfoster99 :uk: (BOB member since 2010-11-05)
