Hi Informer30, having access to database has no relationship whatsoever to your access permission of the BusinessObjects application. Such permissions are usually managed by two completely different teams. And any Enterprise user can access CMC, unless it is explicitly denied.
You need to discuss your permission setting with your BusinessObjects Administrator. He or she is in a better position to help you.
The problem is we no longer have a BO Admin, I am in the process of picking up. I used to look after the CMC around 5 years ago, abit out of synch hence the questions…
thanks for your input the view/edit sql button in webi is know working…
Under Applications/WEBI when editing rights everything is based around groups, what I am trying to do is the restrict the view/edit SQL button to a select few is that possible without creating a new group?
