Think this is more of a limitation report than a request for help but in the Spreadsheet Component you do not seem to be able to centre the text vertically (up and down).
For info, I have a range of cells that then are used as selectors for another component but the length of text is variable so need to give a fair amount of height to the cells to avoid using to much of the screen real estate. This height is not used in all cases and so wanted to use the vertical centre formatting in excel to make things pretty-er.[/b]
simple_simon (BOB member since 2007-09-05)
