The subject pretty much says it all here. I’m using a spinner input control to let users pick a number of months (1-6). It works fine, and changes by whole number (since increment is set to 1.0), but the control displays values like 3.00 instead of just 3, which is what I’d prefer.
Not a big deal, but kind of annoying on this report.
The Input Control is based on a measure variable. I’m not aware of a way to format a variable, other than using functions such as FormatNumber, which I tried, but that did not have any impact on the spinner control.
I’ve also looked at the other control types. The Combo box would actually be a good choice for this report, except for the “All values” option - is there anyway to remove that choice? The Simple slider would also work, but functionally I think it’s easier to use the spinner than the slider.
We are still on 4.0 (not sure which service-pack) - we will be upgrading to 4.1 later this year.
Could you please explain and/or provide a screen-shot on how you are formatting a measure variable for use in a spinner input control? Perhaps that is a new feature of 4.1, or perhaps it’s just another WebI feature that I’m not aware of!
I am familiar with FormatNumber. However, when I apply it to the variable the spinner input control is based on, all it does it changes the initial value to “0”, regardless of what initial value I try to set it to.
I have attached a screenshot showing the results I’m getting. When I set the variable to ‘=3’, the spinner control shows “3.00”. When I set the variable to ‘=FormatNumber(3; “#,##0”)’, the spinner control shows “0”, and then changes to “1.00” when I change it the first time. I believe the reason it starts at “0” (regardless of the value I use in FormatNumber), is because the control does not recognize FormatNumber.
Are you able to suppress the decimals using FormatNumber in 4.1, including the values after you move the spinner up or down?
Yes, it is working fine as is (without using FormatNumber).
As I mentioned in my initial post, this is really just a personal preference to not show two decimal places on the control when it is being used to select a whole number.
