Specify format in Designer
Is it possible to already specify the number format in Designer? I don’t want user to see the two default digits on Year. And also I need to force a date field to present the time only (h:mm:ss) without the user seing the date only first.
hans
************************************************************* Hans Kingma
Unisource Carrier Services
Industriestrasse 21
8304 Wallisellen
Switzerland
Phone: +41 1 839 32 11
Fax: +41 1 839 32 95
Right-click on the object you want to format. You will see a choice called Object Format. Here is where you can set the default format. NOTE: This will only work for new reports. Existing reports will ignore the default format.
Hans,
In Designer, select and object and select EDIT, OBJECT FORMAT.
Jason Beard
AGD Consulting
hans
