SP3 with FP ???
Hi Guru,
we installed SP3 very recently, Want to know if there are any Fixed packs ( FP) avilable at this point of time???
RUC :us: (BOB member since 2010-05-03)
Check the bottom of this sticky topic:
Thanks for the information.
I am bit confused, Please guide me
We are on the BOE XI 3.1 with SP3 and facing lot of issues.
So I am looking for Fixed Packs ??? ( The link show BOE XI 3.3,XI 3.2, XI 3.1 ( I didn’t see SP3 Fixed packs) .
More over the Link shows the downland links for CR
I was referring to this part of the sticky topic:
BO XI 3.3
12.3.0.601 --> XI 3.3 (SP3)
12.3.1.684 --> XI 3.3, SP3 + FP3.1
12.3.2.753 --> XI 3.3, SP3 + FP3.2
Clearly, there are fix packs for SP3 of BO XI 3 version. I have this information from other BOB members so I keep the sticky topic updated.
However, where to get these fix packs is another question :? You’d better contact your SAP BO key account if you can’t find the fix packs in the download section of the SAP site.
Thanks alot
The Fix Pack downloads are available from the SAP Marketplace. This is the link that I use to get there: https://websmp110.sap-ag.de/bosap-downloads. You will need a login ID and password to access it.
There are two Fix Packs currently available. FP3.1 and FP3.2. Make sure you check what’s fixed before you install them. You don’t really want to install them unless they fix a specific issue you are having.
Is there a place we can get the list of things fixed in FP3.1 and FP3.2 without having the login to download them? I am just an end user, not an admin, so I don’t have a login but am tasked with finding this info about issues initially with SP3.0 and what FP3.1 and 3.2 fix. Any info would be greatly appreciated.
mrohlader :us: (BOB member since 2006-01-10)
I’m not sure. Look through this web site: http://help.sap.com/. This site does not require a login.
There is documentation available there but I can’t remember if the release notes for fix packs are there or not.
I have not been able to find them on sap.com but will keep trying. thanks.
FP 3.1 for SP3 has problems with scheduling, I had to uninstall it.
Ottoman :uk: (BOB member since 2002-10-04)
Can you please elaborate?
here are the problems I had, wasted a lot of time on this pack
https://bobj-board.org/t/162740
ottoman
Thanks; I’m on FP3.1 but haven’t had the same problems.
I saw them this morning in the patches section. I’m waiting for FP 3.4, because a java fix that’s supposed to be in there to resolve trust issues that ocassional occur for my users. It keeps getting bumped back as it was supposed to be in 3.1.
Schmitty (BOB member since 2006-11-16)
