Hi Expects,
I run into an issue and need some assistance
Web Service loading with Error MSG XML parse failed: Error Namespace http://… is referenced without import declaration > at line <11>, char<49> in << xsd.schema.
Datastore test okay and also test URL in soupUI and it also tested okay, however DS job fails with above error.
23631 700815136 XML-240304 10/1/2014 3:58:33 PM |Data flow Test_Reinstate
23631 700815136 XML-240304 10/1/2014 3:58:33 PM XML parser failed: Error <namespace
23631 700815136 XML-240304 10/1/2014 3:58:33 PM ‘http:// …FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry’ is referenced
23631 700815136 XML-240304 10/1/2014 3:58:33 PM without import declaration> at line <11>, char <49> in <<xsd:schema
23631 700815136 XML-240304 10/1/2014 3:58:33 PM xmlns:xsd=“http://www.w3.org/2001/XMLSchema”
23631 700815136 XML-240304 10/1/2014 3:58:33 PM xmlns:tns="…FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry"
23631 700815136 XML-240304 10/1/2014 3:58:33 PM xmlns:diws=“http://www.businessobjects.com/diwebservice” targetNamespace=“http://www.businessobjects.com/diwebservice”>
23631 700815136 XML-240304 10/1/2014 3:58:33 PM <xsd:import
23631 700815136 XML-240304 10/1/2014 3:58:33 PM namespace=…FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry’
23631 700815136 XML-240304 10/1/2014 3:58:33 PM schemaLocation=‘C:\ProgramData\SAP BusinessObjects\Data
23631 700815136 XML-240304 10/1/2014 3:58:33 PM Services\ext\webservice\HighRadius.FinancialDocument.Reinstates.Out.WS.WS_publishOAGIS_PostJournalEntrypublishReinstatesWS_publi
23631 700815136 XML-240304 10/1/2014 3:58:33 PM shOAGIS_PostJournalEntry_PortType_publishReinstates0.xsd’/>
23631 700815136 XML-240304 10/1/2014 3:58:33 PM <xsd:element name=“WS_publishOAGIS_PostJournalEntry_PortType_publishReinstates”>
23631 700815136 XML-240304 10/1/2014 3:58:33 PM xsd:complexType
23631 700815136 XML-240304 10/1/2014 3:58:33 PM xsd:sequence
23631 700815136 XML-240304 10/1/2014 3:58:33 PM <xsd:element ref=“tns:publishReinstates”/>
23631 700815136 XML-240304 10/1/2014 3:58:33 PM </xsd:sequence>
23631 700815136 XML-240304 10/1/2014 3:58:33 PM </xsd:complexType>
23631 700815136 XML-240304 10/1/2014 3:58:33 PM </xsd:element>
23631 700815136 XML-240304 10/1/2014 3:58:33 PM </xsd:schema>>, file <<xsd:schema
23631 700815136 XML-240304 10/1/2014 3:58:33 PM </xsd:schema>>.
23631 700815136 XML-240416 10/1/2014 3:58:33 PM |Data flow Test_Reinstate
23631 700815136 XML-240416 10/1/2014 3:58:33 PM Error importing XML Schema from file <adapter_schema_in.xsd>: <XML parser failed: Error <namespace
23631 700815136 XML-240416 10/1/2014 3:58:33 PM ‘http…FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry’ is referenced
23631 700815136 XML-240416 10/1/2014 3:58:33 PM without import declaration> at line <11>, char <49> in <<xsd:schema
23631 700815136 XML-240416 10/1/2014 3:58:33 PM xmlns:xsd=“http://www.w3.org/2001/XMLSchema”
23631 700815136 XML-240416 10/1/2014 3:58:33 PM xmlns:tns="…com/HighRadius.FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry"
23631 700815136 XML-240416 10/1/2014 3:58:33 PM xmlns:diws=“http://www.businessobjects.com/diwebservice” targetNamespace=“http://www.businessobjects.com/diwebservice”>
23631 700815136 XML-240416 10/1/2014 3:58:33 PM <xsd:import
23631 700815136 XML-240416 10/1/2014 3:58:33 PM namespace=…com/HighRadius.FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry’
23631 700815136 XML-240416 10/1/2014 3:58:33 PM schemaLocation=‘C:\ProgramData\SAP BusinessObjects\Data
23631 700815136 XML-240416 10/1/2014 3:58:33 PM Services\ext\webservice\HighRadius.FinancialDocument.Reinstates.Out.WS.WS_publishOAGIS_PostJournalEntrypublishReinstatesWS_publi
23631 700815136 XML-240416 10/1/2014 3:58:33 PM shOAGIS_PostJournalEntry_PortType_publishReinstates0.xsd’/>
23631 700815136 XML-240416 10/1/2014 3:58:33 PM <xsd:element name=“WS_publishOAGIS_PostJournalEntry_PortType_publishReinstates”>
23631 700815136 XML-240416 10/1/2014 3:58:33 PM xsd:complexType
23631 700815136 XML-240416 10/1/2014 3:58:33 PM xsd:sequence
23631 700815136 XML-240416 10/1/2014 3:58:33 PM <xsd:element ref=“tns:publishReinstates”/>
23631 700815136 XML-240416 10/1/2014 3:58:33 PM </xsd:sequence>
23631 700815136 XML-240416 10/1/2014 3:58:33 PM </xsd:complexType>
23631 700815136 XML-240416 10/1/2014 3:58:33 PM </xsd:element>
23631 700815136 XML-240416 10/1/2014 3:58:33 PM </xsd:schema>>, file <<xsd:schema
23631 700815136 XML-240416 10/1/2014 3:58:33 PM xmlns:tns="…/HighRadius.FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry"
23631 700815136 XML-240416 10/1/2014 3:58:33 PM namespace=‘http://…FinancialDocument.Reinstates.Out.WS:WS_publishOAGIS_PostJournalEntry’
23631 700815136 XML-240416 10/1/2014 3:58:33 PM </xsd:schema>>.>. Validate your XML Schema using external schema validators (found at w3.org).
23562 2297669408 RUN-050316 10/1/2014 3:58:33 PM |Session JOB_HR_WM_ECC_REINSTATE_TEST
23562 2297669408 RUN-050316 10/1/2014 3:58:33 PM ERROR…
23562 2297669408 RUN-050304 10/1/2014 3:58:33 PM |Session JOB_HR_WM_ECC_REINSTATE_TEST
23562 2297669408 RUN-050304 10/1/2014 3:58:33 PM Function call <raise_exception ( ERROR… ) > failed, due to error <50316>: <ERROR…>.
Ericvan7 (BOB member since 2014-10-02)
