Sorting Issue
Hello All,
I need to sort a column (% productivity) in descending order.
Problem with this column is , column has few numbers, as well as empty cells and #DIV0. When i apply descending sort, Empty cell and #DIV0 gets the top most position followed by remaining number cells.
I need to push all empty as well as #DIV0 values at the bottom of the table.
Kindly suggest the way.
Custom sort is not working, option is disabled.
Please help. Thanks in advance :smiley: :smiley: :hb: :hb:
bryanket :bahrain: (BOB member since 2009-10-22)
For example, use Alerter and define #DIV0 as -1. Then sort by desc and rows with #DIV0 changes to -1 and goes underneath. The same apply for Null values, consider as -2 or -1.
Also, you may want to hide, tweaks like that. This is the solution that I can think of.
Thanks…
JohnJustus :us: (BOB member since 2007-06-25)
I don’t think that will work. Alerts are really just formatting. I don’t think they will affect sorting at all.
Add a new column using formula : = If (IsNull()) Then -1 Else 0
and then apply sort on that new column
and also apply sort on Colm1.
After then check for required result.
aparna.naik (BOB member since 2010-06-23)
Thanks All.
Its working correctly.
I used IsNull and IsError which will give me -1 and others as 0. And then i sort this column(of -1 and 0) first and then the original . Then hide the cloumn of -1 and 0.
Once again thanks. I appreciate. :rotf: :smiley:
Custom Sort would have been better option for this.
swap_l (BOB member since 2009-04-09)
Hi Swapnil,
Can you pls explain , how to apply custom sort?
Right click on the border of your table
Select Format Sorts
Select Add (add the column you want to sort)
Select Custom
Select Values (define your sort)
REB01 :us: (BOB member since 2004-11-29)
@ Swapnil…
Thanks…
but,
I clearly mentioned that Custom sort is not working… Its disabled…
