Sort with Breaks
I think you’re going to have to add a break to your date column first, and then add a break to your “other” column, so that your report will be ordered by date first, then “other”. I think breaks always take precedence over sorts, no way around that.
Remember, you can control how a break “looks” by using the Format - Breaks menu item. If you turn off the Break Footer and Remove Duplicates options for your date break, you’ll probably get the results you’re looking for.
losiledlighting (BOB member since 2019-06-13)
