HI,
I heard that there is a possibility of sorting throught the recordset in rebean.Can any foucs how can i achieve this.If Possible please provide me with a sample
thnx in advance
gsk
gsk (BOB member since 2004-05-24)
HI,
thnx in advance
gsk
You can do it through SQLSelectStatement. Here is code snippet to handle it.
//.... dataProv is instance of DataProvider
SQLDataProvider sqlProv =(SQLDataProvider) dataProv;
SQLContainer cont = sqlProv.getSQLContainer();
SQLSelectStatement sqlSelect = (SQLSelectStatement)cont.getChildAt(0);
String strNewSQL = "...//your new sql ..."; // your new SQL query goes here. Your new query should have sorting clause ORDER BY <column> ASC/DESC
sqlSelect.setSQL(strNewSQL.toString());
boolean bValidate = sqlProv.validateSQL();
if(bValidate)
boolean bChange = sqlProv.changeSQL();
if(bChange)
sqlProv.runQuery();
Recordset rs = sqlProv.getResult(0); //this recordset has all records sorted by column name :)
chkk213
(BOB member since 2006-07-28)
How can i pass this recordset to the DocumentInstance object? ![]()
How i change the report according to the sorted records?
plz help me or guide me.
Cheers,
SAK
sakshi
(BOB member since 2006-10-10)
I don’t think you can pass a com.businessobjects.rebean.wi.Recordset to document Instance.
What I was doing in my code snippet is that I was trying to run the query and get the Recordset. So that, I can iterate through the Recordset…(I have my own UI for table to display the data in the Recordset)
I think you don’t need
to display you report sorted by any column.
go for webservices API to display report…
chkk213
i could not find any sort method/interface/class in the webservices SDK for sorting the report according to column values ![]()
but i can do it for LOVs…
how can i do it for column values??
plz plz plz help me or guide me
Thank you,
SAK
sakshi
i have done this, but i’m unable to get the recordset according to new SQL, and the record set generated is based on the old SQL(i.e default SQL specific to that report)
i’m using both dataprovider’s runQuery() and SQLdataprovider runQuery() methods.
can u plz let me know how can i do this .??
Is it neccessary to have our own UI for table to display??? or is there any option that we can modify the existing reports recordset??
Cheers,
SAK.
sakshi
Hi Sakshi
These steps are really important to make your customized query run, once you’ve the new query in hand.
if(bValidate)
if(bChange)
sqlProv.runQuery();
Basically my reqmt was more of getting raw recordsets in the sorted order w.r.t any column. Since I have my own Table builder, I used it to display data…
We get recordsets only after successfully running the query. 'am not sure if it’s really possible to modify the existing report, I don’t think it would solve the purpose.
chkk213
Dear Chkk,
can we do this type of functionality by using webservices?
nrkmca (BOB member since 2006-08-28)
Correction. It was taken in wrong way… I mentioned Webservices SDK only for retrieving HTML/XML format of report…
I don’t think you can do sort functionality by using Webservices SDK …
REBEAN SDK would solve the problem.
chkk213
