sort DATE section in descending order
Hello All,
I have a DATE object as a section in my report - which is ascending by default. I want the date section to be displayed in a descending fashion.
Please Help!
damayor (BOB member since 2006-10-01)
I’m not a BO expert but if you’re using the thick client then go to Format -> Sorts and select (or add) the date object and make it Descending sorted.
That should sort you out :slight_smile:
Ruud
Rmantingh :uk: (BOB member since 2006-05-17)
Yes, thats it! I sorted the dates in descending, and then turned it into master. Thanks!
