My question is about the log. When I execute my command, I have no message to see if the import of my atl file was successfull…
Do you know if I can find this information? If yes, Where? Is there a specific parameter to define the output path of the log file?
Do you use this command line? How do you deal with that??
I think it prints a message on the stdout, if there are errors or warning while importing the obejct, these will be logged indefault log files %DS_COMMON_DIR% or LINK_DIR%\log folder in tracelog.txt and errorlog.txt
