[solved] Qaaws, possible to agregate ?
Hi everyone,
I am using QaaWS and wondering if it is possible to get agregated data ?
What I get with Webi (example) :
M. XXX - Holidays - 2 days
M. XXX - Working Days - 5 days
What I get with QaaWS :
M. XXX - Holidays - 1 day
M. XXX - Working Days - 1 day
Database is Oracle.
I think the answer is “use an olap cube” or “use life office” but this is not satisfying (cannot make a cube, live office too much bugs).
Thank you
titlola :fr: (BOB member since 2007-01-10)
hi!
you can try putting SUM() in your day measure in your universe.
regards,
r.A.
R.A. :philippines: (BOB member since 2008-10-28)
I already have SUM in my day measure.
Actually, to be more accurate, I get this result :
With Webi :
OR with object “date” :
date1 - M. XXX - Holidays - 1 day
date2 - M. XXX - Holidays - 1 day
date3 - M. XXX - Working Days - 1 day
date4 - M. XXX - Working Days - 1 day
date5 - M. XXX - Working Days - 1 day
date6 - M. XXX - Working Days - 1 day
date7 - M. XXX - Working Days - 1 day
In fact my QaaWS query seems to see one row per date even if I don’t take the object “date” in the query (I assume date is linked to my object “holiday/working date” in the universe).
Tell me if I am not clear
Thank you for your help
hi!
is the:
“date1”
“date2”
“date7”
are they included in the query?
thanks,
r…A.
No they aren’t but as I said, object “working days/holidays” is the object that “duplicates” the rows. As I said, I assume that object “date” is linked to my object “holiday/working date” in the universe.
hi!
sorry but i don’t understand clearly what you mean by
does this mean that you can’t see inside your universe?
thanks,
r.A.
I can but I didn’t make it and it is quite complicated.
Well all that I know is that object “working days/holidays” is creating the duplicate rows on the date
Hi Titlola,
did you get the duplicates even without your date dimension?
That’s quite weird what is happening.
What you can do is copy/paste of your QAAWS in oracle and check what’s going on also there. I think your problem is the SQL…
By the way if you are using the date object the “group by” will not sum the holidays/working days.
Could you post the sql of your QAAWS?
Cheers,
Luca Spinelli :it: (BOB member since 2008-08-27)
Yes
Do I have the option somewhere to get the SQL in QaaWS ?
Well, if it doesn’t aggregate it means that your “group by” somehow is not working.
About the sql from QAAWS, well you cannot check it…you can just check the pseudo-code from the exported link but it doesn’t help.
If I will get any idea I will let you know.
Apologies for not being helpful :frowning:
I reproduced the query in webi and got the SQL. It seems I have no group by clause, but I don’t know where to add it.
Titlola,
can you post that sql?
If there is not group by I assume that you will not see neither a sum(measure) in the query…
Try to go back to the universe and check wether your measure is like =sum(measure) instead of =measure.
Hope this helps,
Really nice!! This is working well!
Thank you very much for your help Luca!
I’m glad to know that it works ;-)!
Have a nice week end!!!
Cheers,
hi!
[quote:a3de2e08bb=“r.A.”]you can try putting SUM() in your day measure in your universe.
[/quote]
i thought you already have the sum in the beginning. hehehe! but anyways, i’m glad you got it!
regards,
r.A.
What I meant is that I already had “sum” agregation checked in my measure options, not sum(measure) in the select!
hi!
it’s ok! a little misunderstanding there… next time i’ll go into details.
regards,
r.A.
No problem, that’s ok now it’s working :slight_smile:
