[SOLVED] LOV Prompt question
Hi all,
In a DB table, I have the fields “Client Id” ( a numeric identifier of the client) , “Client Name” (The name of the client).
In the report I want the query to filter on a list of “Client Id”: SELECT … FROM…WHERE ClientId IN (List of Client ids) .
This list of clients should be prompted by the report. So something
SELECT … FROM…WHERE ClientId IN @Prompt(…) .
My problem is that - In the prompt - I want to show a list of clients with their ids and their names ( SELECT ClientId || ’ ’ || ClientName FROM clients ) but not just their ids ( SELECT ClientId FROM Clients ). In the query I want to filter on the ids only.
What should I do ?
Thanks in advance for you help,
R
jlinho (BOB member since 2009-05-12)
Edit the client ID LOV in universe. In the Edit LOV query panel, pull Client Name along with Client ID. This should work for you.
vinod_menon :india: (BOB member since 2007-04-09)
Thanks for your rapid answer… I didn’t even now that we can do that ! (I am a total beginner)
Do you have access to Designer ?? (Universe creation)
BOCP (BOB member since 2007-07-02)
Yes
Did you tried what Vinod stated??
Sure I didi and it worked well
