Slow response in CMC
IN CMC, when trying to switch between Folders/Servers or any choice, the respone/load is slow.
Only changes we have made is turn high tracing on CMS, connections and Dashboard Processing.
What is the default trace level on CMS out of the box?
sapaa (BOB member since 2014-02-21)
High tracing will slow things down, as that is simply more transactions to write the tracing data.
You may want to check with your DBA and see if there is anything obviously standing out with the repository DB. You can’t do a lot of tuning with the repository, but you might be able to improve thread management or I/O.
Thank you. I turned off the tracing, do you know what is the default level, or tracing is not enabled by default.
TRACING should ONLY be turned on, when you are troubleshooting a bug/issue IMHO. Otherwise Do turn TRACING OFF.
k, thx,
Tracing was the issue. Servers are good nw.
