Hello,
Firstly, everything works so this is purely a performance question (which I know can be difficult to nail down at times)
My Setup:
- I developed a Crystal Report that pulls back all data (Employee Report)
- Employees are grouped by department
- I created a parameter that will filter based on department and added it to the saved data select expert
- In BO 4.1 I created a schedule to run the report daily
To test:
I created an openDoc that references the last instance of the report:
http:///BOE/OpenDocument/opendoc/openDocument.jsp?iDocID=&sIDType=CUID&sInstance=Last
This returns the full instance within seconds.
I then added the name of the parameter (which should filter the saved data)
http:///BOE/OpenDocument/opendoc/openDocument.jsp?iDocID=&sIDType=CUID&sInstance=Last&lsSEKEY=InfoTech
This returns the employees in Information Technology in about 2 minutes
I recognize that the instance would take a “little” longer to go through the entire instance and filter, but I can’t see it taking that much longer than when there isn’t a parameter passed through (in fact I would suspect because data is being limited it might even be faster)
Am I not fully understanding the way this functionality should work? 2 minutes to filter an already scheduled and completed instance seems a bit off to me.
Are there any ways I can improve the performance of this? Again, everything works, it just seems to be an issue of optimization in my mind?
any help would be appreciated!
ctsui7 (BOB member since 2013-04-09)
