SL SDK Java Export PDF
Hello,
I am trying export the result of a webi document to PDF using SL SDK.
I want to change the metadata (title, author, subject, keywords) of a a PDF.
I think you can use the SL SDK in Java Eclipse that comes in C:\Program Files (x86)\SAP BusinessObjects\SAP BusinessObjects Enterprise XI 4.0\SL SDK\Java to change these metadata that come by default in BO, but do not what is the code that I must apply.
Tanks!!
rubeen03 (BOB member since 2019-03-05)
You can’t use the SL SDK to export a Webi - it’s for working with Universes. You need to use the BI Platform SDK if you want to schedule the export to PDF. I believe you can use the RESTful Web Services SDK to export to PDF also.
-Dell
