Size for a document
Up to how much space(size) allowed for a single document in BO ??
and How many columns/Rows we can maintain for single report in BO??
I got error ::
I understood the problem, let me know about storage capacity for a report and document.
[Edited, removed many empty/blank lines :roll_eyes: thanks, Andreas.]
BOCP (BOB member since 2007-07-02)
There is no limit for the report size, number of objects used. The size of your FRS may have disk limit for storing the files.
Siva.M
looksmee :uk: (BOB member since 2006-02-08)
My error was::
Coming behalf of FRS problem??
How to overcome this??
Check that you have enough space on the drive.
David.Mitchell :uk: (BOB member since 2008-04-28)
May i know where i can check,means which drive…
Is there any limitation on drive capacity ??
In the CMC, go to:
Home > Servers > Input.server - File Repository Server
There you have the server where your FRS is stored, along with the metrics, showing available space.
Okay…,
There is no restriction from BO side …, right??
but FRS has more than 250GB of free space, so it cannot cause this issue.
Can you tell if there is document level or temporary storage related memory setting available.
Hi kishorekumary, we are facing a similar issue. Our universe was made from a BW Query and a similar error message is showed on certain reports (due to report size I guess). Could you find a solution for your problem?
Luis
lchavez :peru: (BOB member since 2005-07-21)
We are using IIS: even if IIS allows 2G maximum space, because of some IIS internal parameters, only a 1.5G is available .
Marc Doucet :canada: (BOB member since 2007-07-11)
Not yet…
May be in CMC—>> Web Server Service settings–>> Memory Cache options you should change…!!
Kishore
      I am also having same error issue. have u found any solutions for this..
Shanthakumar
shanthakumar :india: (BOB member since 2009-06-17)
  Try to increase the Document Cache Size in CMC using the follwing procedure
         i) Login CMC
         ii) Choose servers -> service categories->webi
         iii) Right click the Properties of webi processing server->
Maximum Document Cache Size (KB)
sridharvpy :india: (BOB member since 2011-02-11)
I believe this is a limitation with regards to the size of the BW cube.
Its a BW Limitation, there is nothing you can do from the BO side to correct it, as it is SAP BW causing the memory error.
http://forums.sdn.sap.com/thread.jspa?messageID=9682100&tstart=0
