Stupid time… 4.1 designer and I thought it was the usual issue of working on a dual monitor ands switching to a laptop. But it isn’t. Tried the tricks to move the sub-screen back and there isn’t a sub-screen.
Just trying to access the object properties - no pop-up. I can get a pop-up to format the object, but when I double-click or right click to get at object properties - zilch.
Any bright ideas? I’m sure it will be something very straightforward!
Debbie
ETA: And I’ve read all the old posts on here and tried everything bar a registry hack which I’m not comfortable with. Google shows me lots of ways (in windows 10) to see what windows are open - and the properties sub-window isn’t open. So it’s not hiding - it just isn’t there!
No BO in sight here either. Currently most of my work is backend on SSIS and data warehouse design; reporting is SSRS/PowerBI as with many places these days. PowerBI seems good but SSRS is as clunky as Crystal.
Yep. I’m working on SSIS mostly - again with PBI and SSRS end-tools. To be fair, the users are loving PBI so far. SSRS will be … interesting … and involve a rethink of job roles here, I suspect.
And it was another manifestation of double-monitor-syndrome. Not consistent, since the format pop-up was fine.
Didn’t fancy registry-hacking and I didn’t want to mess with the display set-up as it takes me ages to get the different monitors and resolutions in the right order when I’m in the office … so …
I changed the SIZE of my display in windows 10 settings. Not the resolution - just the size. Made everything smaller and there was the offending pop-up, lurking innocently in the top corner. Dragged it back, smacked it hard and chained it up. Sized back up again and we’re fine.
