com.businessobjects.rebean.wi.CommunicationException: Connection failed. The server has reached the maximum number of simultaneous connections. (Error: RWI 00239)
at com.businessobjects.rebean.wi.occa.OccaConnection.doConnect(OccaConnection.java:226)
at com.businessobjects.rebean.wi.occa.OccaConnection.(OccaConnection.java:66)
Caused by: com.crystaldecisions.enterprise.ocaframework.OCAFrameworkException$ServiceConnection: Unable to connect to service WICDZ from server PUNBI02.KANBAY.COM via CMS osca:iiop://SERVER;SI_SESSIONID=75635JKpS1i9E1ytmFOhy
at com.businessobjects.rebean.wi.occa.OccaConnection.doConnect(OccaConnection.java:221)
My BO server is having named license. when 5 people concurrently accessing reports I am getting above exception. Could you please help in getting solution.
hi Suresh Tavvala,
We are using also BOXI-R2 and in one cluster appeared this problem also. I just found outside here the solution to increase Web_IntelligenceJobServer and Web_IntelligenceReportServer, which are like a workarround, after my opinion.
Did you get any solution from sb else for your described problem ?
Thanx
Georges-Louis
Hi all,
we have just struck this problem - what does the the “I just found outside…” mean - what’s the solution - urgent help required
we run Xir2 on Aix
" I just found outside here the solution to increase Web_IntelligenceJobServer and Web_IntelligenceReportServer, which are like a workarround, after my opinion. "
We had similar error message in our environment and we increased the maximum number of simultaneous connections in Webi Report server settings by 10 and resolve it. We haven’t seen the error message coming up again.
