I was trying to do some POC to extract the data from the SAP ECC table to an SQL Server table, I was getting a column delimiter error when Data Services is reading the .dat file.
I was using the “Shared Directory” mechanism.
How ever I was unable to figure out the column delimiter issue.
But I am able to extract the data from SAP ECC table into an SQL server table successfully with out using a ABAP Data flow, I was using the normal Dataflow and the query transfrom for my extraction.
Can someone help in understanding the significance of the ABAP Data flow and was there any reason why I was getting the column delimiter error while using the ABAP Dataflow ?
Joes
VJ_2523 (BOB member since 2010-10-31)
