I tried to install BOXI R3.1 with default Tomcat and mysql database in Windows.
But in CCM, i’m not able to find SIA so I tried to create it manually and now i’m getting error
“Failed to stop CMS. Please stop CMS manually”
Please advice what should I do to fix this.
saranya
asha_vsv (BOB member since 2010-03-02)
what do you see in the CCM?
pijo
(BOB member since 2009-08-13)
right now only Tomcat is available in CCM.
saranya
What is the plotform you are trying to install on?
Same thing happened to me when I have tried, only find Tomcat !!
laurensm (BOB member since 2007-08-09)
Hello Saranya,
If you are not able to see the entry for SIA in CCM then go to the services. There you should be able to find an entry for Server Intelligence Agent(SIA). You can stop it manually from there.
yaravinds9 (BOB member since 2009-09-15)
did you specify the correct nodename and port during the installation?
pijo
In Services, there is no entry for SIA.
Saranya
You got only Client products installed, not servers, so you can’t find SIA in services. You must be using operating system like XP home or Vista home and not XP Pro or Server editions.
Issue was with firewall, after disabling the firewall, i am able to configure SIA.
Saranya
