Show/Hide when Empty issue
I have a single data provider with some 20 + objects.
The report body is as follows:
Section Start
Table with some 10 columns
Table with 2 columns
and so on…
Section End
Here whenever the “Table with 2 columns” are null ie both the columns are null, i want to hide it. I unchecked 'Show When empty".
It works when the query doesn’t return any row. But when the query return data for the query and even these 2 columns are null, the table is displayed.
since there are some 14 such 2 column tables and mostly null, it wont make sense displaying null blocks that too 14 :shock: .
Any idea where I m going wrong.
Vinesh
VKK (BOB member since 2008-08-21)
