Shift Hours
Hello,
      I have incidents counts happend for each hour in a day. The day is defind in shift hours- which are 8 hour shifts and 12 hour shifts. The data in shift table is flatned. like this....
8_hour_shift…8_hr_interval…8_single_hr_interval… 12_hour_shift
8 hour shift … 7 am - 2:59 pm …7 am- 7:59 am … same for 12 hour
8 hour shift… 3 pm- 10:59pm …9 pm - 9:59 pm…
8 hour shift … 11 pm - 6:59 am…6 am - 6:59 am…
The user wants to see it in object. When we pull this object in Webi - drill mode, then it should show the shift hierarchy starting from “All Shift Hour” under that it should show “8 Hour Shift” and " 12 Hour Shift" under each shift it should show the “shift Hour intervals” under each shift hour interval it should show single hour intervals…
any ideas how can I set the logic in the object/s…thinking of CASE but not sure
by the way we are using Teradata,BO XIR3 and WebI
Thank You
Nikki (BOB member since 2010-04-20)
Not sure what you’re asking for exactly, but you should be able to “chunk” up your days into 8,12 hour blocks by dividing the hour by either 8 or 12. That will give you the “hour group”, then inside the “hour group”, you can use the MOD function to determine which single hour increment it is without the grouping.
  I have SHIFT table with all the values, and I had joined this table with 1:M to the fact table based on incident ID...
In the Shift table I have all the values, 8 hour shifts( 3 shifts in a day-7 am to 2:59pm, 3pm to 10:59pm and 11pm to 6:59 am) and 12 hour shifts(2 shifts in a day)…and I have each shift is broken into single hour intervals like 7am to 7:59am,8am to 8:59am,9 am to 9:59am and so on… hours in a table…
Users need one or two objects showing all these values in each 8 hour shift and 12 hour shift.
Thank You
Right… but if this is to summarize based on when an incident occurred, that should be a timestamp, which goes back to a lookup that determines which hour interval it belongs to.
select rownum as HOUR,
       trunc((rownum)/8)+1 as HOUR8_BLOCK,
       mod(rownum-1,8) as HOUR_IN_BLOCK8,
       trunc(sysdate) + (rownum/24) as HOUR_START,
       trunc((rownum)/12)+1 as HOUR12_BLOCK,
       mod(rownum-1,12) as HOUR_IN_BLOCK12
from   ALL_OBJECTS
               where   rownum <= ( 24 )
