Setup PM repository in another schema other than Unive schem
Can i Setup the Performance manager repository in a different schema other than the schema of the universe tables.
What i mean is that I have created a GL universe which connects to GL user which has the necessary GL facts and dimension.
In order to create the metrics in PM Can I Create a seperate users in which the PM tables are created. so that extra tables are not populated in my existing GL user.
Please let me know weather this is possible.
Thanks & Regards
Ishaq
ishaqbaig (BOB member since 2009-03-28)
Your PM Repository should be created completely separate from the Production DB (i.e the connection being used in the Universe to the Production DB). You need to create a different connection to a DB that will contain the PM tables. You have to ensure the connection has read/write permissions to create the required PM tables.
Zulfiqar_Taj (BOB member since 2002-09-16)
