Setting user preferences for InfoView
I want to be able to modify user preferences (for all Infoview users) in such a way that when they log in, they are directly taken to the ‘Favorites’ folder.
I dont see an option anywhere in the CMC where I can do this for all users.
Please could you advise? I am the super-admin of the system so I have full access
zigzag :us: (BOB member since 2009-09-13)
Check this if it helps:
Hi zigzag,
If EPM is installed on the system then you can do this in one go.
Please let me know if EPM is installed.
Thanks!!
Noti (BOB member since 2009-05-01)
@Marek - Thanks, will check it out
@ Noti - No, not installed
