I just use XI 3.1 but it could be the same way to do what you want
I work with CMC in french so my translation could be wrong some times
Let’s try :
In the CMC
Go to Access levels
Create an access level “sales reader”
Right click on it and select “Included rights”
Click “Add/remove rights”
In the left panel select Content/WebI
Check the options you want (to be able to access wbeI docs)
Do the same for Content/Crystal (to be able to access crystal docs), Sytem/Connection (to be able to access data) and System/Universe (to be able to access universes)
Still in the CMC go to folders
Right click on the folder you want and select “User Security”
Click Add users/groups
Select your group and click “add and affect security”
Select the good access level and click OK
Still in the CMC go to universes
Right click on the universe folder you want (where your universe is) and select “User Security”
Could you tell me more about :
Everyone’s access levele on InfoView App :
In the CMC go to --> Application --> Infoview (or BI Launch Pad) --> right click --> user security
Everyone’s access level on top folder :
In the CMC go to --> Folders --> Manage --> top level security --> All folders
Everyone’s access level on root folder :
In the CMC go to --> Folders --> right on root folder --> user security
A: View
A: I get a menue “You have choosen to set top level security”
Everyone: General->Delete Objects->Denied
A: At Root folder I do not see “user security” in the right mouse menue.
On any folder on user security “Everyone” has no security assigned.
a) Going to have a hard job doing this without training, as little is written about the new security model and you are totally new to Business Objects.
b) Have trouble with someone helping you here, as most are not using 4.0 yet and things always change between versions.
→ May be it’s not root folder but public folder
A: At Root folder I do not see “user security” in the right mouse menue. → click on Properties and you will find “user security” in the new window
