sending email from bca
l have this report in bca that is creating the pdf file and everything else, but l can’t make it send emails. l have included the correct smtp information and l also have a simple smtp application which l used to test the smtp server and it is working just fine and sending me emails, but not the bca report. Thanks,
Public Sub SendEmail()
Dim ObjMessage As CDO.Message
Dim Cfg As CDO.Configuration
Dim doc As Document
Dim docname, tempdoc As String
Dim Rep As REPORT
Dim i As Integer
Set doc = ActiveDocument
doc.Refresh
doc.Save
docname = doc.FullName
tempdoc = doc.Name & format(Now, "MM-DD-YYYY hh\hmm")
doc.SaveAs (tempdoc)
For i = 1 To doc.Reports.Count
Set Rep = doc.Reports.Item(i)
Rep.ExportAsPDF ("C:\Reports\" & Rep.Name)
Next i
On Error Resume Next
Set ObjMessage = New CDO.Message
If Err.Number <> 0 Then WriteError (Now &amp; " " &amp; Err.Description)
'establish server settings
Set Cfg = New CDO.Configuration
Cfg.Fields(cdoSendUsingMethod) = 25
Cfg.Fields(cdoSMTPServer) = "mysmtp host"
Cfg.Fields.Update
ObjMessage.TextBody = "Text in e-mail!"
ObjMessage.subject = "text subject in e-mail"
ObjMessage.From = "my email"
ObjMessage.To = "my email"
ObjMessage.AddAttachment ("C:\Reports\" &amp; Rep.Name &amp; ".pdf")
Else
WriteError (Now &amp; " " &amp; "C:\Reports\" &amp; Rep.Name &amp; ".pdf" &amp; " Added")
End If
Next i
ObjMessage.Send
Else
WriteError (Now &amp; " Message sent")
End If
Kill tempdoc
Else
WriteError (Now &amp; " " &amp; tempdoc &amp; " deleted")
End If
End Sub
Public Sub WriteError(Err_Description As String)
'The error_text.txt file where the messages and potential error
'message are going to be saved.
Open "C:\error_text.txt" For Append As #1
'Print #1, Err_Description
Close #1
End Sub
[When posting code samples please use the code option for formatting. It will preserve any indenting or formatting that you may have done. Thank you, Andreas]
abieyuwae (BOB member since 2004-06-07)
This FAQ has a link to an existing script that uses CDO - it might be worth a look to see if you can spot a relevant difference between it and your script.
