sending document to DAS without running it interactively
I want to send a document to DAS without running it interactively.
All I want to do is…
Create the query, and send it Directly to DAS for execution. The reason being, the query output takes a long time and holds my machine.
Please suggest a way out.
Ashish
Ashish,
Try this:
create the query
click options
select “do not retrieve data”
click ok to go back to the query panel
click run
This will take you back to the report view without trying to pull the data. Save your file then send it to doc agent.
Shelley
Ashish
But the “Do not retrieve data” option is atill checked. What do I do about it ? Will it not affect the DAS output ?
I tried doing so …but no luck… the query took a long time and ended with a message " Partial result "
Ashish
