send to BI inbox
I have one user who is trying to send a webI report to a BI inbox. In the list of available recipients they only see a handful of users, the complete user list is missing. When I login with my user (who has administrator permissions) I see the complete list of users and am able to send to any BI inbox. Where is this permissions set? I want to remove any restrictions so users can send to anyone other BI inbox.
4.1 SP07
bension (BOB member since 2005-09-01)
I think I figured out the issue with some trial and error. I had to set the permission under ‘Users and Groups’ -> Manage -> Top Level Security -> All users. The everyone group has advanced access. I had to update to include the right ‘View objects’.
That’s one way to do it. It will allow everyone in the system to send documents to any other user. If you only want your users to be able to send documents to other members of the same group, you use the method described here.
Joe
Won’t that have a SIDE EFFECT, though ?
When you do NOT set this, users searching for “ABC document” will get a search-engine response including only documents who are (directly) visible to them.
When I tried and opened the “usergroups - toplevel” to Everyone, suddenly the “ABC document” was found … in OTHER users’ personal folders.
for “ABC document” there is no harm in it, but IF that document is built on universes the user can use, (s)he can also refresh its contents etc.
And … it turned out that management people had documents revealing “too much” in the NAMES. Wich was fine, because within personal folders, they SHOULD be private (visible to the user only, and TECHNICALLY visible to BI system administrators who have a codo of honor / confidence / security … they see everyhing, but like hotel staff: they won’t talk.
RensH :belgium: (BOB member since 2007-06-18)
