BusinessObjects Board
Send Report in Email Body
I have a requirement wherein I need to send the Web-I report contents to user in Email Body… rather than sending a link or as an attachment.
Is there any way to do so?
Jai
enjoyy2j :india: (BOB member since 2008-04-17)
Publication…
Prashant Purohit :india: (BOB member since 2009-02-18)
yes, in XI3.x, you should choose the mHTML format as output, configure the destination as email then choose in the pull-down menu of the message the %SI_DOCUMENT_HTML_CONTENT% variable
Bernard
Hi Thanks for the reply
I dont see the mHTML format at all. I have attached the screenshot of the Scheduling options.
I am using BOXI R3.1
This is only possible for deski-reports
pijo :netherlands: (BOB member since 2009-08-13)
So I believe there is no way to send the Web-I report in the body part of the Email
  1. Add the webi report into publication
  2. Select the format as mHtml
  3. Schedule the report.
I have sent the webi report in an email through publication.
kanukula (BOB member since 2007-05-05)
:shock: wrong statement…
please follow the steps mentioned by Rajesh.
Cool…
Well I dont have the Publishing tool in my installed folder…
I see Publishing Wizard where I can select .rpt format and all other formats but not .wid
is it different from Publishing?
r u working in XI3.x version of webI?
publication is not a separate tool, you can create new publication through infoview…goto document folder -> right click -> New -> publication
Yes I found that… Thanks for your input anyways :slight_smile:
I followed same steps to schedule a publication . My destination is email address , After scheduling publication status always showing pending . Can someone let me know what could be the problem .
patriot3029 :india: (BOB member since 2006-12-08)
Thank you all. I did learn something new through this post.
I was able to achive the tast of sending the report in an email body to the user.
Environment:
BO 3.1 SP2
Now, my scenario is
I have a report with, say suppose, 4 report tabs.
Each tab has 4 graphs in it respectively.
Now, with these options i was able to send one report tab(consisting 4 graphs) in the email body to the user.
Out of those 4 graphs in one report, I want to send only one graph in the emailo body to the business user.
Is there a way to do that. Can we say, pick this block from one report tab and embed it in the email body?
Please, I will appreciate your inputs.
I hope I was clear with my question. Let me know if need any further details.
sil_bob
sil_bob (BOB member since 2011-12-06)
