I want to select all rows depending on the level of the hierarchy. <
Create an alias for the table, one for each level in the heirarchy, thus for EMP right click on the table in the structure pane.
Select insert alias and make the alias MANAGER. Then just handle as if two tables.
Jonathan Bliss, Product Consultant
McKessonHBOC Computer Centre,
Harold Wood Hospital site, Gubbins Lane, Romford, RM3 0NE mobile:0498 668084, tel 01708 336135 (direct line with voicemail), fax 01708 376270
Fine for known number of levels but I think the question is really ‘how do I do Oracle tree walking in BusObj?’ The FHS option is one but has anyone done anything through a universe? Is the only way by using a db side function/procedure?
Jonathan
Project Leader
Group Medical, Regulatory and Product Strategy IS.
