Security issues of using Adobe Flash
Hello Everyone,
Is there any known security issue for the current usage of Adobe Flash with BO 4.2 SP5?
Are there also related articles related to this?
Do you have some recommendation for customers on early versions of BO who are at risk?
Thanks & regards
alancutaran (BOB member since 2011-11-18)
To be honest, there’s no real benefit to using Flash with BO, unless you’re restricted to an older version and have to use Xcelsius
It was used for the Monitoring application in CMC, too. Not sure which specific version switched to HTML.
