Security Deployment for Users
Dear Friends,
As I am new to BO security, need your help in providing the security
We have three user types
UserA – are responsible for Data quality and integrity
• Can create reports directly in Production
• Can publish the report
• All reports can be publish to corresponding folder for Business Area and folder category
User B
• Have only to execute the report
• Can create personal reports
User C * They can execute any reports that they have access
User D
• They are creating reports from Dev environment and all these reports cannot be modified by any other user types
Please ssist which kind of security need to create
Thanks & Regards
Md_Fasi (BOB member since 2011-11-19)
Start here:-
https://bobj-board.org/t/119849
Thanks for your wonderful reply Mak1.
Could you please let us know once the security is developed in BO 4.1.
Can we transport to QAS and Production ?
(I am assuming with help of Promotion Management we can do it. But would like to know the content…like what I can select objects, users & Group…)
Can I have standard content to select during import .
You can do this, however it is quite usual for there to be different users and possibly groups in different environments. You do this with Promotion Management, so you should read up on it.
Hi Mak1,
Thank you very much for providing the information.
Could you please provide BI 4.1 /BO 4.0 if you have such kind of templated
It would be great !
Thanks & Regards
Dont have one, Im afraid.
Maybe you can indentify the differences which are documented and create one for version 4 and then share :)?
Sure,
Definitely, right now I am too much busy with Project.
I will create and share with you
