Scripts on BO
I wanna make a script that refreshs a document but i don’t know how to pass parameters.How can i do that?
Thankx in advance,
Marco Lopes
Marco A. de M. Lopes
FID - Tel : (21) 559 - 7716
I assume that the parameters you want to ‘pass’ are the prompts?
Using script, create an Application or Document Variable with exactly the same name as the prompt. And set the value to the valaue you want to enter for the prompt.
Ie. if you have a prompt like “1. Today’s date:”
Then in the script:
Dim bovar1 AS BOVariable
Set bovar1 = Application.ActiveDocument.Variables.Add(“1. Today’s date:”)
bovar1.Value = “2000-03-29”
Application.ActiveDocument.Refresh
From: Lopes, Marco BRAZIL-FID [SMTP:Marco.M.Lopes@SHELL.COM.BR] Sent: 29 March 2000 16:18
Sensitivity: Private
Thankx in advance,
Marco Lopes
Web archives (24 hrs. a day now!): listserv.aol.com/archives/busob-l.html
Create a report that uses a prompt in the condition and call it something like “Variable”.
Put this in your script:
sub main()
Application.variables.Item(“Variable”).value = “XXX” Application.Documents.Item(1).Refresh
end sub()
Its works :))))
But i couldn’t bypass the prompt’s confirmation (when you choose the correct value for the variable)
Sent: Quarta-feira, 29 de MarÁo de 2000 11:47
for the prompt.
Then in the script:
Add this as your first line.
Application.Interactive = False
Vasan
Marco.M.Lopes@SHELL.COM.BR on 03/30/2000 12:47:22 PM
cc:
Its works :))))
for the prompt.
Then in the script:
******************************************************************************* Note: The information contained in this message may be privileged and confidential and protected from disclosure. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. Thank you. Ernst & Young LLP
