I didn’t intented to bump the post, its just that the subject line for my previous post was about Trim function & i asked you back about scripting.
So just re-posted the same thing with subject line as scripting so that people who reply don’t mis-understand my query.
I will refer to the technical document, however in case you had any spare time & have knowledge of scripting then do let me know answer of the 4 points i raised in my query.
Well on the actual post, you will have to have a basic coding/SQL Scripting knowledge to understand what the Custom Function does…and of course the thought/effort to understand what it is doing…
As Shazin said, the basic things are already there in the User Manual. In the Tool Palette, you will see a symbol of , just click and search for your topics!
Forum can help you solve only specific issues and not a broader picture of what we can do!
In 1st line its printing the email address along with concatenate the actual email variable, while in 2nd line its printing the load date along with concatenate the actual variable of Load date.
However, I am not sure why @ is used & whats the difference between using single ‘@’ & double ‘@@’.
I’d say I do know my way around the BODS scripting language but I have never used anything related to @ characters?
From a first glance, I’d say it would only just print the @ character as indicated? Especially as it’s not surrounded by brackets used for in-line variables etc?
Then again, I could just be wrong (yes, that does happen ) and it’s something new that I have never seen before!
