Has anyone ever done a script on the repository to set the “Use Custom SQL” button on? If so could you share the script?
jchandlerAxis (BOB member since 2012-02-29)
And why would you need that for?
Below is one of the pointer to your query, though it might not be possible to do that task using SDK
Do further search in SDK forum
haider (BOB member since 2005-07-18)
